HELP ME PLEASE: Battery removal 2006 S.S.
Old Dec 12, 2012 | 01:56 PM
Ricks 2006 SS's Avatar
Question HELP ME PLEASE: Battery removal 2006 S.S.
ok. I thought this would be about a 20 min job to remove the old battery and put in a New one ARE YOU freakin kiddin me. Holy crap Batman I can't even figure out how to get the old one past the fuse block on the shock tower !! Can someone PLEASE give me a few hints on how to do this ? Its a V8 2006 SS. man I need help badly! Thanks for any short cuts or help you can give me. Rick
Old Dec 12, 2012 | 03:06 PM
From Mitch...Prior Post
11-05-2011, 12:07 PM
trewyn15
2004 Chevrolet Monte Carlo
pull the wires off, neg first then pos.
then remove the fender brace, there will also be a bolt on the engine side of the battery that you need to loosen because it holds in the battery, once those are all off just pull the battery out
https://montecarloforum.com/forum/ge...ed-help-31946/
^ Click above for the link to this subject ~> GOOD LUCK
Old Dec 12, 2012 | 03:20 PM
It's a VERY tight fit for the LS4.
I had removed the face of the fuse box and moved it as much as I possibly could, and it was a matter of tilting the battery very carefully and trying to maneuver it out.
Old Dec 12, 2012 | 03:25 PM
Hi Rick, found the below & it's for an Impala S.S., but it should be the same...They don't build cars for us to work on..
Good Luck.....I hope the below helps
How to Remove a Battery From a 5.3L 2007 Impala
How to Remove a Battery From a 5.3L 2007 Impala | eHow.com
Old Dec 12, 2012 | 03:35 PM
Default Battery question & help
Ok nsit back and read this. I need your help. My 06 SS V8. Well the battery is dead. I bought a new one and want to take the old one out! That where the PROBLEM IS.. Took the brace off. and took the fuse block loose on the shock tower. But can't move it enough to get the battery out of there. Now theres got to be a trick to getting that thing out of there PLEASE! Has anyone ever did this before ? HELP.....Someone. Or just shoot this oldman Thanks Rick
Old Dec 12, 2012 | 03:52 PM
MIKE: Is that a 2 piece fuse block ? I got it away from the shock tower but it won't move enough to get the battery out! The wires just won't spread that far.
Old Dec 12, 2012 | 03:56 PM
sent you a PM Mike.
Old Dec 12, 2012 | 04:53 PM
03SSLE's Avatar
Disconnect the negative battery cable
Remove the right front diagonal brace
Reposition the positive battery cable terminal cover (1)
Loosen the positive battery cable terminal nut
Remove the positive battery cable terminal from the battery
Remove the battery retainer bolts (1) and retainer (2)
Remove the battery
Old Dec 12, 2012 | 06:09 PM
Well after 3 guys tell you the samething. I guess thats what has to be done. Don't ask me how. But I got it out with my wifes help! Thanks Honey. I don't know how I'm going to get the new one in there ?? it was a BITCH ! I want to have a face to face with the engneer that designed that. So I can kick him in the NUTS ! Thanks Mike , Space & Seattle Mike
Old Dec 13, 2012 | 07:54 AM
I just saw your PM this morning. I don't really check the forum in the evening haha
Glad you got it out!
