6th Gen ('00-'05): help installing knock sensor 2000 ss monte carlo 3.8
Old Apr 18, 2014 | 11:48 AM
montecarlo89's Avatar
Default help installing knock sensor 2000 ss monte carlo 3.8
I need help finding the knock sensor on my 2000 monte carlo ss any pictures or info on where it is or how to get to it would be great! thank you. this is also on bank 1.
Old Apr 19, 2014 | 06:55 AM
03SSLE's Avatar
Bank 1 knock sensor is located on the radiator side of the engine block below the exhaust manifold. You'll need to drain the cooling system to replace it. Then support the car on jack stands, unplug the wiring harness then remove the sensor.
Did you get a code for it? Have you checked the wiring harness? With an ohmmeter jumped across the terminals of the harness (or terminal and ground on 1 wire sensors) you should have a reading of approx. 100K ohms. If not, trace the wiring back to the PCM checking for damage. If the wiring is good then the problem is in the PCM, not the sensor.
To test the sensor backprobe the terminal (blue + / gray -) or (blue + / ground) with a volt meter set to AC. Start the engine and check for a voltage signal. The signal should increase as you accelerate. If no voltage is present or doesn't increase when you accelerate replace the sensor.
lilcayer
Mar 21, 2014 10:44 AM
FLNGMP
May 11, 2013 10:09 PM
philly94ss
22
Nov 7, 2011 02:27 PM
laredoggg
Nov 10, 2006 07:34 PM
