HELP! Best way to fix replace engine cradle?
Old Sep 26, 2010 | 06:52 PM
dirtybird's Avatar
Default HELP! Best way to fix replace engine cradle?
Have a 2000 monte ss. The control arm bushings went bad and separated and now they have worn into the engine cradle. Whats is the best way to change the engine cradle out? Any one know if it can be done somehow without pulling the motor? Also any ideas on changing the control arm bushings? I have read on another thread that its easier to just replace with new control arms with the bushings already installed?
Old Sep 30, 2010 | 06:38 PM
One Dark SS's Avatar
haha, i just replaced mine a few months back... its honestly not that hard... just time consuming...
you don't have to pull the engine out, but you will need to figure out a way to support the engine from above... i cant remember all the exacts steps but off the top of my head here is what i remember.
You will have to unbolt your steering rack from the K-frame
Basicaly remove the control arm off the K-Frame
Remove sway bar
two bolts for the tranny to the k frame, same for the engine on the other side
MAKE SURE WHAT EVER IS HOLDING UP YOUR ENGINE IS STRONG ENOUGH TO TAKE THE WEIGHT
You now have four bolts, one in each corner of the K-frame, should drop out
Hope you realized that you'll to jack your car and put the jack stands where it wont be in the way of the K-frame
MillerMonteSS
Jan 16, 2011 10:03 AM
One Dark SS
May 14, 2010 09:26 AM
Brubaker
May 6, 2010 06:33 PM
monte carlo 3831
Jul 9, 2009 09:03 PM
Ddobbi
Mar 30, 2009 07:28 PM
