Help ABS an Traction control
Hi guys got a problem again, no abs no traction control, no abs light or traction light when key is turned, no abs or traction control lights when running, triple checked fuses, no check engine lights, please Help
I'm not sure I completely understand what the symptoms are. I'm going to re-state what you have listed:
- no abs no traction control (not sure how you are determining this)
- no abs light or traction light when key is turned (I assume you're talking about when the car does a check on the lights when it's started, they never come on? If so, could just be dead bulbs in the cluster).
- no abs or traction control lights when running (again, I wonder if it's just dead bulbs)
What happens if you hit the traction control button on the center console while driving? If the system is working, the car wil ding at you that you turned traction off.
If the car has detected ABS and/or traction system has a problem, it will light up the lights on the dash and with the right scan tool or scan program, you can check for trouble codes in the ABS computer (not all scan tools can access this data).
Another possibility, is this car equipped with ABS and traction control? I know my ex-wife's '05 Impala does not have that option.
Thanks Maniac, ill try to break this down, after i got the car abs and T.C. worked no brake lock ups no spinning tires. abs and TC always showed on start up. T.C. always dinged if i turned it off. as it is now brakes lock on wet pavement and tires spin also. replaced tc switch, checked all fuses 3 times
mwmarshall
May 14, 2022 02:43 AM
Chris s
Jan 27, 2013 04:30 PM
tridski
Jun 26, 2006 09:55 PM
