heating problem please help
Old Aug 31, 2012 | 06:01 PM
garcia3.8's Avatar
Default heating problem please help
i have an 01 monte carlo ss and the temp. gauge goes up to 2 lines over the middle. i already replaced the thermostat, temp sensor, water pump, belt tensioner, took the radiator to get flushed and cant find the problem. the fans are direct with a relay so they do work. if any one has any idea what it could please help me out thanks in advance.
Old Aug 31, 2012 | 06:11 PM
DE02Carlo's Avatar
How is your coolant mixture? Does it have many other mods?
Old Aug 31, 2012 | 06:15 PM
garcia3.8's Avatar
100% antifreeze and only mod is cool air intake
Old Aug 31, 2012 | 08:35 PM
aussiek2000's Avatar
There's the problem. Needs to be 50/50 mix. Straight antifreeze actually freezes sooner than straight water.
Old Aug 31, 2012 | 08:43 PM
Never run...straight antifreeze !!
60/40 is even fine....but 50/50 is the usual mix...
The system needs water....to perform properly...
Old Sep 1, 2012 | 09:34 PM
garcia3.8's Avatar
Ill do that then i didnt think that would be a problem but i try it
zyon555
17
Mar 9, 2023 08:20 AM
oneandonlydylawn
Jun 2, 2013 02:15 PM
zyon555
May 27, 2011 09:51 PM
chamberz
Jul 15, 2009 02:02 PM
connersdad19
May 29, 2009 03:24 AM
