Heater not blowng enough air ?
Old Sep 29, 2008 | 03:38 PM
yzf125's Avatar
Default Heater not blowng enough air ?
Hey guys, I have a problem with my 02 monte. when i have it on cold air or A/C it blows fine, But when i put the heat on it seems to drop way down in air volume !
When its on 5 it seems like its on 2 or 3. ( But sounds like its blowing hard just cant feel it )
I have already replaced the cab filter and there seems to be nothing clogged in that area.
Anything else i could check ? Thanks!
Old Oct 4, 2008 | 11:40 AM
yzf125's Avatar
Default RE: Heater not blowng enough air ?
Wow, Anyone have any ideas ?
Old Oct 4, 2008 | 12:59 PM
ORIGINAL: yzf125
Hi YZF, from N.Y.
Below is a idea I found during ReSearch
From your description, There are three possibilities that come to mind.
The first being a problem with your vaccuum source hose. It may be disconnected or have a large enough leak that it is not sending the vaccuum to your harness connector. Your vaccuum source usually comes from your brake booster. I would start there.
The second possibility is that your harness connector that sends the vaccuum to different actuators dependent upon where you select with the switch may be faulty and is no longer opening/closing the correct valves.
And the third possibility is that your control head is not sending the appropriate electrical signals to your vaccuum harness connector to make it change valves.
I would first verify that your source hose is connected and is in good condition. Then make certain that your vaccuum source is pulling the appropriate amount of vaccuum. (Typically 8-10 inches of mercury vaccuum)
If these check out, I recommend taking your vehicle to a reputable shop and have them diagnose it further. They will have the appropriate equipment to determine where your fault actually lies. Digging into it yourself will not only be time consuming, but also can get very confusing if you are not knowledgeable in the manner the vaccuum/electric system works.
Be Patience, and hopefully one of our expert Members
will post their solution/opinion/comment.
Good Luck
Old Oct 5, 2008 | 04:59 PM
RocknSS04's Avatar
NA! You got a broken resistor block which controls the fan speeds. Not real expensive part, maybe $35, but a pain in the b__t to get to. It's on the heater box on the passenger side, WAY up there.
SSMike
Sep 7, 2012 08:08 PM
ladybridgeport
15
Dec 27, 2011 02:02 PM
knightfan26917
Mar 26, 2009 10:03 PM
sadeem
Jul 4, 2008 12:35 AM
fever42
Dec 8, 2006 10:24 AM
