Heater & A/C Panel Light Out
Old Nov 22, 2011 | 12:35 AM
Vladimir's Avatar
Default Heater & A/C Panel Light Out
Someone told me they aren't likely replaceable that I just need the whole new faceplate. On top of the light out I have a problem where on setting #3 it is super finicky, like not in the exact right spot it stops work...
Do I need the whole new thing, in which case what part is that?
Old Nov 23, 2011 | 01:05 AM
Vladimir's Avatar
Found the link below, sure hope that is not what I need!
PartsTrain.com - Hard to Find Auto Parts and Truck Parts - - $150
Old Nov 27, 2011 | 04:11 PM
TKG2000's Avatar
Here is the story as I understand it from the following:
biggriggs:
The bulbs inside all of the dash parts are "non-serviceable".
Usually that means that they're either soldered into the board inside, or are inside of a sealed part that a dealer would just replace (as in they'd replace the whole climate control interface).
It can be done, but not easily. There are a few places around that will do it (bbengineer.com being one of them) and that will also do LED replacements of the bulbs if you wish (you can change the back-lighting color that way).
-Riggs.
AwesomeSS:
There is a thread floating around here that goes into detail about fixing the climate control bulbs - you need to be good at soldering and have a soldering iron and sucker. The bulb part number from radio shack is 272-1154 and you will need, if I recall correctly, 6 bulbs if you want to replace all of them.
biggriggs:
changing your dash lights to L.E.D.'S HOW TO ARTICLE
Found it. It was in the sixth gen "How-To" section.
Hope this helps.
Old Nov 27, 2011 | 09:07 PM
I've seen a few of these for sale here before. Maybe try looking in the PRIVATE For Sale/Trade Classifieds section and see if you can find one. It may be a long shot but if you can save some cash it will be worth it.
Old Nov 27, 2011 | 09:43 PM
Old Nov 27, 2011 | 09:44 PM
mouseman
Feb 9, 2013 06:34 PM
chamberz
Jan 17, 2011 09:35 AM
sunshine1979
Oct 28, 2010 06:50 AM
weizie
Feb 25, 2010 07:41 PM
Mex24x
29
Feb 17, 2010 12:35 PM
