Heat will only blow towards seats, will not defrost front windsheild
Old Dec 19, 2013 | 05:10 PM
tloughrin's Avatar
Default Heat will only blow towards seats, will not defrost front windsheild
My 06 Monte Carlo just started having this issue. No matter what position i have the dial to direct the air it will not blow on the windshield. Even during remote start.
I recently had the right side blend actuator replaced, could this have something to do with it?
Is there a fuse?
Old Dec 19, 2013 | 05:14 PM
Is there a fuse?
I would say it definitely could be the problem... IF, The defrosters worked before the blend door repair/replacement was done.
Old Dec 19, 2013 | 07:34 PM
tloughrin's Avatar
Yes it definitely worked before that and after. I would say it stopped working within the last week. The actuator was replaced back in October.
Old Dec 22, 2013 | 08:47 AM
tloughrin's Avatar
Update:
I unplugged the battery and that must have rest something. It is working fine now.
Also got my Rear defroster working. It was that damn connector under the fuse box on the passenger side.
MJClemm
Aug 4, 2013 11:41 AM
seawolf18
Apr 3, 2012 10:49 AM
Emnasty600
Jul 2, 2011 09:38 AM
jarheadbobandmax
Oct 22, 2009 05:00 PM
nankipoo
Aug 14, 2009 09:28 AM
