6th Gen ('00-'05): Headlights not bright enough
Old Jan 7, 2016 | 07:22 PM
Coatesy_24's Avatar
Default Headlights not bright enough
I am new to this forum I looked around a bit but didn't find exactly what I was looking for. The headlights on my 02 just aren't bright at all and there is very little difference between the high and low beams. I have already changed out the lights for brand new ones and i didn't help. Any suggestions on how to get nice bright lights?
Old Jan 7, 2016 | 07:42 PM
plumbob's Avatar
Poor ground wire connections cause all kinds of electrical problems as our cars age and rust and/or corrosion sets in. I suggests checking those grounds. Here's a link to a thread that addresses a similar headlight problem:https://montecarloforum.com/forum/mo...h-beams-54676/
Another culprit could be the dimmer switch which is part of the Multi-function switch.
Old Jan 7, 2016 | 10:15 PM
How are the lenses? If they are cloudy, yellowing or pitted they won't project well, but they can probably be polished
Old Jan 8, 2016 | 08:16 AM
plumbob's Avatar
Good point "Junior Car", those plastic lenses can get dull.
If problem seems to be electrical here's a great thread posted by one our Administrators, "ChibiBlackSheep" listing common problems with our Montes including Headlight issues: https://montecarloforum.com/forum/fw...lutions-30154/
