Headlights
Old Jan 4, 2022 | 06:05 PM
sicilian88's Avatar
Default Headlights
My headlights dont worl my driving lights and my high beams work and its not a fuse or a relay
need some feedback please
Old Apr 17, 2022 | 02:16 PM
Glen01SS's Avatar
Default 01 headlights not working but everything else does
I recently had this problem and the short answer is that I had to replace the multifunction turn signal switch that I replaced 5 years ago, even though I haven't driven the car much for the past 2 years. I replaced the headlight switch with a good used unit after checking bulbs and grounds, no joy. I replaced the headlight relay (which is IN the dash on the BACK of the driver fuse panel - had to use a long punch to knock it loose to get it out, no hand space), no success - it was good. I replaced the ambient light sensor on the top front of the dash - very little slack in the wire, that didn't work. So last in - first out, replaced the multifunction switch and all is working again.
Old Apr 17, 2022 | 03:18 PM
Sounds like it's time to break out the wiring diagram and a multimeter.
Z28350TPI
May 23, 2020 01:37 PM
Ted Holman
Mar 2, 2020 11:58 PM
Myshell Ray
Mar 22, 2017 12:51 PM
Dj_bosse
Mar 3, 2016 08:18 PM
yeyeee01
Sep 8, 2010 02:18 PM
