Converting 2 light headlights to 4
Old May 22, 2020 | 09:22 PM
Z28350TPI's Avatar
Default Converting 2 light headlights to 4
Hello all.
I want to make it so my Monte has all four of the front lights on when they're on the normal setting, and not just when you put on the high beams. Has anyone done this? If so what do I have to do?
Old May 23, 2020 | 07:47 AM
Theyll all turn on like that if you have your regular headlights on at night then pull the brights switch back and hold it.. Where theres a will theres a way, I just dont know how to keep them on permenently. Ive always wanted to however..
Old May 23, 2020 | 01:37 PM
Steelbizkit's Avatar
Image is for a Chevy truck but applies for any really system.
https://images.app.goo.gl/QF7nWNou6kzfE4XT6
hell have run those from high beam relay out to low beam relay out, and same for fog/driving lights also. Just run the highest watt diode to help with power feed back.
​​​​​​​https://www.amazon.com/dp/B0071DZVDU/ref=cm_sw_r_cp_awdb_t1_U6wYEbBDSPX0J
wetherb67
Feb 9, 2019 09:14 AM
Myshell Ray
Mar 22, 2017 12:51 PM
Dave McFly
Jan 21, 2013 10:27 AM
MJClemm
Jan 27, 2011 01:27 PM
yeyeee01
Sep 8, 2010 02:18 PM
