Headlight Adjustment
Old Sep 19, 2011 | 07:55 PM
tloughrin's Avatar
Default Headlight Adjustment
I just bought black Depo Headlights for my 06. The low beams were out of alignment so I fixed them. For the life of me i cant figure out how to adjust the high beams .
Any help is appriciated
Old Sep 19, 2011 | 09:14 PM
xxtheshockerxx's Avatar
RED DEVIL
i dont think you can adjust the high beams. i never did and there is only one screw for adjustment.
Old Sep 20, 2011 | 02:55 AM
Zeke's Avatar
xxTheShockerxx is 100% correct ...
Same deal with my '03 SS ...
Old Sep 20, 2011 | 05:20 AM
tloughrin's Avatar
So then any ideas on why they are so far off from each other?
Old Sep 20, 2011 | 06:40 AM
I've searched the MCF & also my search engines for the answer to your problem with no luck..
I suggest that you contact the manufacturer that made them, or the company that sold them to you...
Check back on your thread to see if any of expert member's may be able to help & make a post...
Good Luck
Old Sep 20, 2011 | 08:34 AM
Did you seat the actual bulb incorrectly on the high beams? Sometimes people miss a tab, or they don't push the bulb in all the way before they turn it.
Old Sep 20, 2011 | 09:06 AM
Yeah id agree with chibi cuz the highs shpuld be the same unless one headlight is way off from the other
Old Sep 20, 2011 | 05:10 PM
tloughrin's Avatar
I checked the both bulbs, they are in correctly. The drivers side is higher that the low beams and the passenger side is lower than the low beams. The high beams are supposed to be higher than the low beams correct?
Old Sep 21, 2011 | 01:59 PM
I believe they are the same height, just the low beams have the reflector in front of them.
Old Sep 24, 2011 | 01:50 PM
tloughrin's Avatar
I called the company and they sent me return label. Sent them out yesterday., now to wait another week or two to get my new headlights.
