Having a whistle noise from the motor
Old 05-26-2016, 01:03 PM
pswatts0122178's Avatar
Originally Posted by pswatts0122178
The crankshaft position sensor and the fan
But the fan fuse is blown
Old 05-26-2016, 01:05 PM
Sounds like a potential vacuum leak to me.
Should it do it all the time if it was that it only does it at running temp and at idle
Old 05-26-2016, 01:14 PM
Can it possible for it to be the trans or the egr value
Old 05-26-2016, 02:06 PM
plumbob's Avatar
Check the PCV valve for a missing O-ring. They are often missing when you buy a replacement.
Air could be rushing past the PCV causing the whistle.
Try taking the PCV valve out and test run without it to see if the noise goes away.
Old 05-26-2016, 05:30 PM
When I bought the car it didn't have one in it and it still done it
Old 05-26-2016, 05:48 PM
plumbob's Avatar
Just saw this thread this afternoon. A shop thinks it's the harmonic balancer.
There's a rubber bushing between the two piece pulley. Possibly slipping?
Thread: https://montecarloforum.com/forum/mo...e-54423/page2/
Old 05-26-2016, 05:58 PM
O I forgot to mention that I put one in
Old 05-26-2016, 06:00 PM
Thanks I will look at that tomorrow
Old 05-26-2016, 07:26 PM
O I forgot I took the belt off and it still does it
Old 05-26-2016, 08:14 PM
plumbob's Avatar
Any chance you can make a video with audio and upload it on YouTube, then copy the link and paste it in a post here?
Does it sound like this?
Commentary on this video doesn't say what the cause was (hate that), but one guy said he had the same noise caused by a vacuum leak from the upper intake manifold gasket near the MAP sensor. I would also check where the throttle body connects to the UIM. You could try a rudimentary smoke test by moving a smokey cigar around those gaskets to see if smoke pulls in.
Another possibility is a dirty IAC valve with a stuck pintle, but that usually effects the idle. Might be worth checking out though.
If you have access to a scan tool capable of reading fuel trim values check them. Ideal readings are 0% Short term and 0% Long term. Anything more than about + or - 10% would be a strong indicator of a vacuum leak.
