hard starting
Old Jul 22, 2007 | 12:05 PM
97montelt's Avatar
Default hard starting
ok, been havin problems with my 97 monte. first off, it sat for 2 years with the batt. disconnected. when i finally got around to it, i did the manifold gasket replacement, and a new egr as well. put a new battery in, and it takes forever for it to finally start. almost to the point of killing the battery. when i do get it going, it idles fine but has a bad hesitation when i throttle it, until it warms up. now i know that the pcm loses its memory when the battery is disconnected, and has to relearn all the values again. but this happens everyday. oh, and once its running and warmed up. it will restart like normal. i`m starting to pull my hair out. any ideas what is causing this ??? Thanx
Old Jul 25, 2007 | 08:00 PM
04 Intimidator's Avatar
Default RE: hard starting
First I would do a quick tune up: air filter, plugs and wires and go from there.
Old Jul 25, 2007 | 09:14 PM
97montelt's Avatar
Thanks for the reply. I`ve done the plugs( those back 3 are a real pleasure lol) air filter, pvc, oil change, coolant change. Have not done the wires yet. will try that next. I was thinking maybe a fuel problem, but it`ll rev to 3000 without stumbling. just hard to start when cold, and a bad hesitation.
Seppeku
Oct 8, 2017 08:35 PM
Dean Skibicki
16
Sep 11, 2015 04:12 PM
mrgears
Sep 26, 2014 06:43 PM
gkathleenw
Feb 29, 2012 11:03 AM
Redline29
Dec 7, 2011 08:50 AM
