6th Gen ('00-'05): Handling 6th Gen...
What are some of the best mods some of you have done to improve handling of the 6th gen Monte's? I am more into handling these days...
Wheels, tires, bushings, lowering springs..?
Thanks,
Thanks,
I see the front tower strut braces on ebay but not rears. Where did you get yours?
I added front and rear Strut Braces from ZZPerfromance.com (got the pair for less then $100 shipped on Black Friday). Very happy with those.
I also have Energy Suspension front poly sway bar bushings and end links. Honestly, I don't see much difference with those, but at least they won't degrade like the old rubber ones.
As much as I am against lowering a daily driver, lowering your car and putting wider tires will help with handling.
Also GMPP used to make a handling kit, but it was discontinued. However you can still probably piece together one.
Front and rear strut tower braces are good, changing a lot of the bushings in parts / replacing those parts with higher quality replacements.
34mm front sway bar, trailing arms, there's a rear sway bar but i'm not sure of the fitment.
