H.I.D harness hook-up Q
Old Sep 27, 2010 | 11:42 AM
misteresscoupe04intimidator's Avatar
Default H.I.D harness hook-up Q
hey guys!
I'm willing to do just about ANYTHING if someone helps me with my h.I.ds...
I got the zzp wiring harness to run them from the battery post separately can I use the battery post aux located above the batt as my power supply for the harness? And the running lights run off the high beam bulb 9005 btw 9006 is the low beam incase you didn't know plse somebody help I just got my harness 2day...
Old Sep 28, 2010 | 03:25 AM
This should not be a problem. Just make sure everything is tightened up well. I;v seen people hook amps and other accessory's up to that spot before.
Old Sep 29, 2010 | 01:11 AM
Cool thanks alot ;D
boston989
17
Oct 5, 2014 03:17 PM
labnjab
Feb 16, 2010 04:10 PM
KingSize
Oct 9, 2006 05:05 PM
LilDesire
Jun 15, 2006 02:39 PM
Intimadator4
May 27, 2006 06:33 PM
