6th Gen ('00-'05): Grounds
G100- negative battery cable, rear of the battery, on top of the right frame rail.
G101- top left front of the radiator support.
G111- top right of the engine, below the ignition control module.
G113- lower left of the engine, on the automatic transaxle stud near the starter.
G117- lower left of the engine, on the automatic transaxle stud, above G113.
G151- on top of the left frame rail, right of the left front strut tower, under the air cleaner/pcm housing.
G171-on top of the left frame rail, forward of the left front strut tower.
G201- under the I/P, right of the steering column,on the I/P support bracket.
G202- under the I/P, center of the dash behind the radio.
G203- under the I/P, right of the steering column,on the I/P support bracket
G301- under the driver door opening, aft of the left A pillar.
G302- under the pass door opening, aft of the right A pillar.
G309- on the right C pillar, near the right lower corner of the backlight.
Thanks I had no idea there were this many grounding points on this car.
