6th Gen ('00-'05): Grounds
Old Jul 1, 2020 | 06:20 AM
Mike Palatka's Avatar
Default Grounds
I have a question about where I can find all of the grounding points on my 2003 SS Monte Carlo?
Thanks in advance,
Old Jul 1, 2020 | 06:53 AM
monte boy's Avatar
G100- negative battery cable, rear of the battery, on top of the right frame rail.
G101- top left front of the radiator support.
G111- top right of the engine, below the ignition control module.
G113- lower left of the engine, on the automatic transaxle stud near the starter.
G117- lower left of the engine, on the automatic transaxle stud, above G113.
G151- on top of the left frame rail, right of the left front strut tower, under the air cleaner/pcm housing.
G171-on top of the left frame rail, forward of the left front strut tower.
G201- under the I/P, right of the steering column,on the I/P support bracket.
G202- under the I/P, center of the dash behind the radio.
G203- under the I/P, right of the steering column,on the I/P support bracket
G301- under the driver door opening, aft of the left A pillar.
G302- under the pass door opening, aft of the right A pillar.
G309- on the right C pillar, near the right lower corner of the backlight.
Old Jul 1, 2020 | 08:22 AM
Thanks I had no idea there were this many grounding points on this car.
Old Jul 6, 2020 | 12:41 PM
I checked my car this weekend and I only found the ground off the battery.
Adam Esposito
Nov 9, 2016 10:13 AM
stu5280
Nov 24, 2015 08:06 PM
DANCEMAN
Oct 15, 2014 12:44 AM
bigmyyke
Apr 14, 2014 11:55 AM
JFMonteCarlo03
Apr 8, 2014 09:14 PM
