gasket trick or just weird?
Old Jun 2, 2007 | 12:02 PM
saluteTOme's Avatar
Default gasket trick or just weird?
I work with a guy who used to be a machinic. I was telling him about how i will be replacing a few gaskets on my 66 327. He then told me that I should use a silver spray paint and paint the gaskets, let dry then install. He said the silver paint has metal flakes and therefore better seals. Any input on this?
Old Jun 2, 2007 | 12:32 PM
wiz kidd's Avatar
Default RE: gasket trick or just weird?
well felpro performer gaskets come with bits of metal inside them...so i guess that could kind of make sense that way...but i dont think what he's saying would work...what gaskets are you changing?? because valve cover gaskets are really the only ones that really suggest these metal in them..and the felpro # comes with the metal in it on those
Old Jun 2, 2007 | 01:15 PM
Mrrench's Avatar
years ago we used to use a copper spray on head gaskets..... NOITICED I SAID YEARS AGO
Now days the gaskets you get are much better made plus you will find that they have a sealant built into the gasket that has replaced the need for sprays
Old Jun 2, 2007 | 01:40 PM
saluteTOme's Avatar
I bought and have in front of me fel-pro gasket kit for my block.I really bought it for my timing chain cover cause that is leaking, but bought the entire kit just in case something else needs to be replaced. But THere are all kinds of different looking and material gaskets. I guess w/e is needed for the application. The timiing chain cover gasket is more a paper sorta gasket where as the intake manafold is like a harder, kinda plastic material gasket
Old Jun 2, 2007 | 03:54 PM
mickey's Avatar
i always use pentex puprle on mine, it is also a felpro product i belive,.
or i will use the copper spay on the pan,waterpump and vlave cover gaskets when i build a older 350 motor. I absolutly hate a leaking motor.
Might explain why my hog never marked it's spot also. I made sure i did anything i could to make sure it wont happen.
they look like crap when ya look at them, and depending on what is leaking it can be veryy dangurouse.
what your frend is talking a bout is in the old days some folks thought that the silver paint was like the copper coat. in reality it was not close. but when you would stick the gaskets in place and tighten them up it would seal due to teh paint being there and being sticky on both sides of the gasket and there fore would stick to the parts also.
BUT IT IS A PITA TO GET THEM CLEANED OFF LATER.
Old Jun 3, 2007 | 09:19 AM
saluteTOme's Avatar
thanks boys...I think I will just throw them on.
New2MonteNY
Apr 25, 2017 01:59 PM
BeachBumMike
Sep 5, 2007 02:52 PM
wiz kidd
Apr 20, 2007 12:20 AM
wiz kidd
Feb 13, 2007 11:45 PM
Nix_SS
Oct 10, 2006 02:14 AM
