Gas type
Gas type
I was just sittng here looking around at things for the my monte and a thought came to my mind...what kind of gas should be used? I know I been having running problems but I thought and still more or less think it's just to ignition and tuning and such, but should the 1966 327 use a higher grade gas? I can only find "gasoline" under the gas type. It doesn't say anything about octane. I figure it's regular, but since there has been a bit of work done to it, should i put plus or prem in? My thought is it might be running like such cause of lower octane gas.
What you guys think?
RE: Gas type
ORIGINAL: 2000LS
where are u at? i thought all pumps in the US were legally required to have a big yellow octane sticker next to the nozzle/selection buttons...somewhere obvious on the pump
RE: Gas type
well you could just go ahead and try it, but lower octane actually ignites easier and contains more BTUs, only reason to run higher octane is if its knocking.(i'm sure others will say otherwise)
also, u have a known good carb? other engine u can try it on? good carb u can borrow to see if it helps?
just ask because i've known so many ppl that go through this, but are convinced thier carb is fine, try everything else first spending as much money as a new carb, then finally borrow a known good carb off a good running car to have it solve thier problems, and then get a new carb.
RE: Gas type
octane=anti-knock
http://www.ftc.gov/bcp/conline/pubs/autos/octane.shtm
holleys are good carbs
guy i work with has 2 80s full size trucks both with holleys, couldnt seem to ever get either truck to run like he wanted, threw lots of parts are em, finally he borrowed a holley off his dads 70s vette that was runnin great, put it on one of his trucks... truck ran great.
RE: Gas type
My dad has a 69 dart 340 engine and will only putSHELL high octane in it becasue if he does not it will "run on" after he turns it off or will run crapy and will have less power.
Also if you have a higher compression engine then you should run high octane is what i have always been told not sure if its true though
RE: Gas type
personally in your car i would just be running 87, or 89@ most, those cars already burn through enough gas, putting premium in in those isn't going to do much i dont think
RE: Gas type
Even though gas is out of control, I am not too worried about it...I wont be and havn't been driving it much. I rather fork over the money to have it run well then nickle and dime and have it not run to what it can do. Thats going to be on my do to list. Drain the gas tank and start putting in preium. Just enough to see how it runs at 1st.
I know the engine has fuelie double hump heads....I can only guess that it has aftermarket pistons and rods.
