gas petal sticks
Old Jul 14, 2010 | 09:06 PM
02montecarlo's Avatar
Question gas petal sticks
Hey everyone I've noticed ever since I bought this car my gas petal sticks in the am and when I get out of work...does this mean a sticky throttle body plate n could be causing my terrible gas mileage?
Old Jul 15, 2010 | 08:24 AM
Yes your throttle body is probably completely caked with Carbon.
Time to take it off and clean that sucker. No that's probably not the cause for your bad gas mileage. You need to start with everything for gas mileage. Plugs, Wires, Filters, Etc.
I noticed when mine was sticking in the AM (you have to push really hard real fast and then it's fine) It looked like this when I replaced it for an HVTB
Old Jul 15, 2010 | 09:20 AM
Post
I just has a major tune up 6 months ago n my mileage never got better.. I took her in the other day n they said its my bank 1 o2 sensor and my throttle body needs to be cleaned...so I replaced the o2 sensor but still not any better n ima clean the throttle body this weekend.. I'll keep you posted to see if it helps. Please prey I'm sick of my bad mileage. O by the way it looks like my throttle body gasket is starting to seperate from the manifold. Maybe that's the reason for my mileage being so bad
Old Jul 15, 2010 | 10:00 AM
Was your battery every disconnected for an hour to let the PCM go back into Relearn procedure after the O2 sensor was replaced??
Old Jul 15, 2010 | 10:08 AM
No I didn't think I had to considering the engine light was never on in the 1st place.. I'll try that later today. But what do you mean procedure?
Old Jul 15, 2010 | 10:12 AM
Procedure is just terminology used.
Your PCM learns how much fuel to use and etc. And then uses those figures while you drive. When you change something you should always let it go back into the Relearn "Mode" so it goes back to the stock settings and then learns with the new things.
Old Jul 15, 2010 | 10:25 AM
So your basically saying the pcm thinks I never changed anything. Which one should I disconnect, the neg or positive or both...I jus wanna do this right
Old Jul 15, 2010 | 10:29 AM
Neg for an hour.
I'm not saying this is going to magically fix your problem, but it's worth a try.
Old Jul 15, 2010 | 11:20 AM
I'll give it a try later...want to know my outcome? If so I'll keep you imformed
Old Jul 15, 2010 | 11:29 AM
Always nice to keep us informed
