gas gauge fluctuates
my gas gauge fluctuates when it reaches about 1/4 tank or so.... only when car is on. As I drive will show 1/4 tank, then it moves up to 1/2 tank or 3/4, when i shut car off it returns to the normal position. When the tank is full or half at least, it always stays put..... could this just be a sensor issue? easy fix? It's a 99 Z34
Yup that was the first stage of my sending unit problem. At first it does that. then it will read a half tank then it goes to straight full all the time and doesn't work at all. Which is where mine is at. Been to lazy to replace it so I just do the mileage calculation. When I get back and I do my top swap build I'll pull it out. But you should start looking into it now. Everyone else in this thread is absolutely correct.
There is an access panel located in the trunk. A few screws and viola you're pump is in your hands.
