fuel system list
I would completely take the throttle body off the engine to clean it. The side facing the engine is going to be the dirtier of the 2.
Take the intake hose off, take the engine cover off. Unbolt 3 bolts and the connectors and the TB slides right off. 89 IN/lb when you put it back on.
Bank 1 o2 sensor is on the rear manifold. Not the easiest to get to, but not entirely hard either.
Does a dirty throttle body plate cause poor mpg or is that just the mechanic wanting more money n the 02 sensor is the real cause of my poor mpg
Hahaha :cough: :cough: ahem https://montecarloforum.com/forum/sh...ad.php?t=21874
Well, where the hell did that come from???? Ahhh double post, me so sowee.
So only use throttle body cleaner right not even carb cleaner correct? N how would I know if its my fuel pressure regulator.. is it suppost to twist and if I push down on it is it suppost to stay solid when car is off or spring back up?
