FUEL PUMP ASSEMBLY
Old Jan 24, 2008 | 09:07 PM
cali2000ss's Avatar
Default FUEL PUMP ASSEMBLY
I have a 2000 Monte Carlo SS 3.8. I need to change the fuel pump asembly and I was wondering if I had to drop the gas tank or can I take it out from the access panel in the trunk ? It looks like it's not screw down it seems to be turn and lock type. Can anybody help me with my problem. Thnaks cali2000ss
Old Jan 24, 2008 | 10:05 PM
2000LS's Avatar
Default RE: FUEL PUMP ASSEMBLY
take it out through the access panel....
on the.... "It looks like it's not screw down it seems to be turn and lock type." ....i'm not exactly sure what you mean here, i belive there is a ring that goes around the top of the pump that holds it down, and you want to turn/unscrew that only, not the pump.
Old Jan 24, 2008 | 10:27 PM
cali2000ss's Avatar
Thanks for the help..
Old Jan 25, 2008 | 08:56 AM
1977Monte's Avatar
if its the style im thinking of you should be able to get it with a flat blade screwdriver and hammer.. just pay attention to how it looks now..
ReaperSS
Aug 29, 2014 11:35 AM
2002 SS
Mar 1, 2014 05:01 PM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
PCWeber
Mar 11, 2007 10:58 PM
Monte Python
Jul 11, 2005 02:56 PM
