6th Gen ('00-'05): Fuel Pressure Regulator Replacement
Old Aug 25, 2016 | 08:10 AM
owens91's Avatar
What I had to do was get a special tool that removes the u clip holding the fuel pressure regulator Down then it will pop back up I didn't have to unbolt anything when I have replaced mine but I would still follow the steps to relieve fuel pressure that Mike mentioned
Old Aug 25, 2016 | 08:37 AM
Yeah, it's a snap-ring holding it down, so you need a snap-ring plier.
My initial instructions over-complicated it because I didn't realize that it was just sitting in the cup and that was just general FPR instructions that I pasted over.
But that website that I found should guide you through step-by-step
Old Aug 25, 2016 | 10:43 AM
KKrueger24's Avatar
Yes that is great instructions! Thank you guys so much!
Old Aug 29, 2016 | 10:19 AM
KKrueger24's Avatar
Yeah... looks like it's 2 pieces and held on with a snap ring.
Check out this website: Daniel Armbrust's webpage
Thank you so much for sending me this guide! I replaced it this weekend, and wow what a difference that made! She purrs like a kitten now Thanks again good buddy
Old Aug 29, 2016 | 10:32 AM
Glad it worked you!
Old Aug 29, 2016 | 10:36 AM
KKrueger24's Avatar
Glad it worked you!
Yes it did like a charm... There was tons of fuel in that thing I cant believe the shop wanted to charge me a $180 for that, and that was not even with the AC Delco part. They said it would be after market part, and if I wanted the AC Delco it would be at least 140 for the part... I got the AC Delco part from Amazon for 60 bucks... Unreal
Old Aug 29, 2016 | 10:48 AM
Mark-up on parts is there, shop rate was probably $110/hour or roughly around there.
That's why I try to recommend these easy jobs that can be done with basic hand tools get done at home.
Old Aug 30, 2016 | 08:21 AM
owens91's Avatar
Does changing the regulator improve mileage by any chance that anyone know of?
Old Aug 30, 2016 | 10:06 AM
No, it should only regulate the pressure so that your car runs optimally. It's a change it if it's broken only part.
