6th Gen ('00-'05): Front windshield seal/trim
My 2001 Monte LS has old, dried out window trim that is coming up in the corner. (wasn't leaking though before I moved it into the garage) I did some internet searches, but can't find anything specific on how to replace it.
The windshield is in great shape. what's the process to replace the trim and can it be done in your garage by a layman?
Thanks.
Thanks.
IMO...This is a job for the pros and their special tools. Here's a video showing the process, not a Monte, but the procedure is similar.
Question: Is the windshield seal/trim really the source of your leak. The urethane caulk used to seal and bond the windshield is tough stuff and rarely leaks.
If your problem is water on the front passenger side floor it might be the very common problem of water leaking through air deflector above the cabin air filter due to a design flaw.
Here's a great thread with pics. posted by our awesome administrator ChibiBlackSheep: https://montecarloforum.com/forum/fw...lem-fix-26663/
Thanks.
Thanks.
The window isn't leaking, it's just the driver side top corner is torn away (see picture) I hate to replace a perfectly good windshield because of the trim, but if it's best as one piece... not an immediate need anyhow. just research. Thanks!
