6th Gen ('00-'05): Front windshield seal/trim
Old Mar 13, 2016 | 12:24 PM
nichols2k's Avatar
Default Front windshield seal/trim
My 2001 Monte LS has old, dried out window trim that is coming up in the corner. (wasn't leaking though before I moved it into the garage) I did some internet searches, but can't find anything specific on how to replace it.
The windshield is in great shape. what's the process to replace the trim and can it be done in your garage by a layman?
Thanks.
Old Mar 13, 2016 | 02:52 PM
plumbob's Avatar
IMO...This is a job for the pros and their special tools. Here's a video showing the process, not a Monte, but the procedure is similar.
Question: Is the windshield seal/trim really the source of your leak. The urethane caulk used to seal and bond the windshield is tough stuff and rarely leaks.
If your problem is water on the front passenger side floor it might be the very common problem of water leaking through air deflector above the cabin air filter due to a design flaw.
Here's a great thread with pics. posted by our awesome administrator ChibiBlackSheep: https://montecarloforum.com/forum/fw...lem-fix-26663/
Old Mar 13, 2016 | 04:51 PM
Thanks.
The trim around the windshield comes with the new windshield . It wraps around the glass.
Old Mar 13, 2016 | 09:48 PM
nichols2k's Avatar
The window isn't leaking, it's just the driver side top corner is torn away (see picture) I hate to replace a perfectly good windshield because of the trim, but if it's best as one piece... not an immediate need anyhow. just research. Thanks!
