front seat removal?
RE: front seat removal?
there are two bolts int he rear of the seat and two in the front .
after that you have to worry about any wires etc... that you might have for heated seats and seat belt buzzer etc...
once you get one side up you should be abel to rock it up some so you can find the others and also unhook the plugs.
Belive they are a big torx bolt but it has been awahile
curious, not t jack the thread... but I was thinking of putting in racing seats. what would I do about wiring and such when i pull out my seat? follow the wiring someplace and pull that part? can I disconnect it from the seat? also, what about the dash light about "buckle seat belt" icon? I plan on getting a 4 point harness.... so, i wont be using the stock seat belt.
i know this is old but ill reply to it since i just got new seats........
theres 2 bolts on teh back and thats it..no bolts on the front ....when you lose the bolts on the back lift the backof theseat up and pull back slow because of all the wires ....and thats it..........
i replaced my CREAMCOLOR LEATHER SEATS TO BLACK LEATHER SEATS.........I HAVE NOW AN EXTRA FRONT AND BACKSET IN MY BASEMENT LOL
good luck
good luck
thanks
good luck
good luck
Thanks, Im doing my drivers seat tomorrow... , I was gonna ask, but found this thread....MJC
Simple...
good luck
good luck
Hello, Man I did my seat and I'm embarrassed on even asking about how to do it... It took under 10 minutes to remove and replace the drivers seat, and thats with the wire hook up and all. Now I have an EXTRA Power drivers seat...LOL Thanks for the info though, It helped a ton. I was getting a ton of tools ready and it only took 1 tool...lol thats it, just 2 TORX bolts and its out (I unplugged the wires first).. I really thought it was gonna be a JOB... But as usual, I was wrong...lol.. thanks again...MJC
MJClemm
12-15-2013 12:05 PM
