Front and Rear Speaker Wire Colors 02 MC
![Exclamation](https://montecarloforum.com/forum/images/icons/icon4.gif)
Hey guys Im having troubles finding out which is the (+ & -) on my Front and Rear speakers I have found wire diagrams but they dont match the colors that I see on my car
if I unplug the plug from original speakers Front or Rear the colors that I see for example on the Rear ones is
driver side Rear white / lite brown.
and other side on Rear is lite brown / red.
or where can I get the right diagram 2001 MC.
HELP!!!!!
THANKS ALL.
HELP!!!!!
THANKS ALL.
Hope this helps.
Constant 12V+Orange
Switched 12V+ Yellow
Ground Black/White
Illumination Gray/Black
Dimmer Brown/White
Antenna Glass
Front Speakers 5 1/4" Doors
Left Front (+) Tan Left Front (-) Gray
Right Front (+) Light Green Right Front (-) Dark Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown Left Rear (-) Yellow
Right Rear (+) Dark Blue Right Rear (-) Light Blue
Constant 12V+Orange
Ground Black/White
Dimmer Brown/White
Antenna Glass
Hope this helps.
Constant 12V+Orange
Ground Black/White
Dimmer Brown/White
Antenna Glass
Constant 12V+Orange
Ground Black/White
Dimmer Brown/White
Antenna Glass
mine is not a premium factory sound system is got an amp on the rear deck and im just unpluging the fact speakers and pluging in aftermarket ones! so i dont know which is neg or pos either fornt or rear>!!
![Roll Eyes (Sarcastic)](https://montecarloforum.com/forum/images/smilies/rolleyes.gif)
Sorry I was not able to help on your thread/PM question on
what wire to connect.
Thanks Mod J.J. for posting/helping with your information.
I hope that one of our Expert Sound System Member's can ~>Help & makes a post....
Member Spiknek, needs 2 hear his sounds : )
HELP!!!!!
THANKS ALL.
HELP!!!!!
THANKS ALL.
I hope one of our experts reads your problem and can assist/help 4-Sure.... Sorry, I can't help on this one : (
Keep check'in back & don't give `up : )
Well, I dont have the car today, well about 8 hours. Ill go out there later when my wife gets home and figure everything out for you. What exactly are you wanting to do, just find the speaker wires?? I went through this whole thing a week ago but I bypassed the amp, what I can tell you is, the colors coming out of the amp are different from the speaker wires going into it. and the back speakers, brown is neg.
Yes, in the rear the red and white are the pos, but they are different colors in the back of the stock stereo. Once the speaker wires are coming out of the output harness of the amp, the speaker wires change colors. So all you are doing is changing the speakers, and keeping the headunit and stock amp right??
Hang on Im looking for my paper, I wrote all the colors down. Do you need all four speaker colors?
