6th Gen ('00-'05): Front end noise
Old 02-08-2021, 06:50 AM
MarcP's Avatar
Default Front end noise
My 01 ss has started make front end noise which sounds exactly like the sound rough terrain truck tires make on the road. I rotated the tires thinking maybe a front tire went bad or something. The noise didn't change at all. The car has 145,000 miles. Any ideas on my problem?
Old 02-08-2021, 07:31 AM
Get your front end off the ground. Can you wiggle the wheels at all?
Old 02-08-2021, 08:00 AM
MarcP's Avatar
I'll try that today. If they do what are your thoughts?
Old 02-08-2021, 09:16 AM
Usually means one or both the wheel hubs are worn out.
Old 02-08-2021, 10:33 AM
MarcP's Avatar
Is that something a carpenter with limited mechanical abilities could do??..... lol
Old 02-08-2021, 09:21 PM
There is usually a Youtube video for everything.
Old 02-17-2021, 12:43 AM
wheel hubs are easy to do. hadest thing is to get the actual hub bolt off, use penetrating oil alot of it for a day or two before trying, get a breaker bar (don't use a ratchet), get some pipe to go over the breaker bar for extra leverage, more penetrating oil, hit it with a hammer a few times, more oil, then have a go at it. Add heat if needed then more penetrating oil. It was the hardest nut or bolt i've ever taken off on the car.
Old 02-17-2021, 08:22 AM
The one upside to the whole thing is that the nut is out in the open so you're free to use any / every tool at your disposal to get it off. You can literally stick a 6 foot cheater pipe on it if you had to.
I've had a couple oddball sub frame / suspension bolts and crank bolts that were probably a bit lower torque but were harder to remove due to limited access.
Old 02-17-2021, 09:07 AM
MarcP's Avatar
That's exactly what it was. It was fairly easy actually. When I unbolted it, it fell apart. I was lucky as hell that didn't happen on the road. It's all fixed!
Thanks for the help everyone!!!!
Old 02-17-2021, 12:06 PM
Are all these wheel hubs the same? I have the Supercharged with the TPMS. I know it has ABS. I have found two that are alike. One appears to have a molded plug fixed to the back of the bearing, the other has a lose lead about 3 inches long with a clip. Are they both correct?
Kyle Pike
10-18-2017 04:46 PM
sethery
02-06-2011 02:08 AM
mini64
06-14-2010 07:46 AM
roboticboredom
11-26-2008 04:26 PM
Quick Reply: 6th Gen ('00-'05): Front end noise
