6th Gen ('00-'05): Front Driver's-Side Coak Noise (VIDEO)
Crunk, Croak, Almost a knock noise is coming from my 2001 Monte Carlo SS front drivers side... somewhere, sounds like the engine bay near the firewall. This happens when I switch from Drive-Neutral-Reverse, or coming from park, accelerating will also create the noise.
I've bounced on the car to see if it's suspension and I cannot get it to reproduce.
I had my girlfriend in the car shifting back and forth from Drive-Neutral-Reverse-Neutral-Drive over and over while Im in the engine bay trying to find it. It's hard to hear because of the engine running but I cannot find it (yes, I used a stethoscope when i got desperate).
Anyone else get this?
I have a quick video but note that it really sounds like a knock in the video. It sounds more like a croak in real life. The video will 'show' the noise at 0m:12sec:50ms, 2 back to back at 0m:16sec:50ms, 0m:24sec:00ms, 0m:25sec:50ms, 0m:27sec:50ms, 0m:29sec:00ms, 2 @ 0m:30sec:00ms
Now that you've heard them, when I accelerate from stop from being in park or backing out of a parking spot, I get 4 or 5 croaks back to back like the 2 back to back in the video.
Here is the video
Here is the video
I had the croak in the steering column. A hefty spray of Lithium white into the boot from inside the car made that one go away.
No, this one is very likely something to do with the forward and reverse motion of the engine and transmission. I jumped up and down on the car and could not make the suspension say a word.
MonroeŽ Strut-MateŽ mounting kits are direct fit replacements designed to complement the ride control characteristics of Monroe struts. In addition, our full line will provide you with late model original equipment coverage.
When doing strut replacements, it is important to do the complete job. This means not only replacing the struts but also inspecting and replacing worn strut mounts. Remember, worn strut mounts can adversely affect a vehicle's safety and handling.
Not only are strut mounts a necessary component of the suspension system, they consist of rubber to metal bonded parts that wear out over time as well. Worn bearings may also cause noise, steering binding, vibration and vehicle pull.
The fronts are symetrical, and the rear plates are left and right specific.
Replace your worn strut top plates with brand new ones. Front plates are a complete assembly and include the bearing and rubber pad.
If your car isn't moving at all when you hear it I wouldn't suspect the suspension to be the cause.
Check all your motor mounts. I mean I wouldn't say that is the cause for sure but since shifting causes the motor to rock a little I would check them out and rule that out of the equation right off.
Yeah I know you said it was near the firewall but the engine is anchored to the car and where the sound happens can actually be a ways from where the problem is. Just a suggestion anyhow.
Not to absolutely bring this out from the grave buuuuut... I found the noise to be caused by the sub frame right at the connections in the back (mounting bolt areas). I saw a service bulletin for shims to be installed but I cannot find the parts. GM doesn't know what I am talking about but the service bulletin is pretty clear. None the less, I need part number: 10306243
Any ideas where I can get that?Google turned up very little.
