fogs and headlights
Old Mar 24, 2015 | 07:25 PM
avendo's Avatar
Default fogs and headlights
can you get fogs to stay on with headlights without pushing button?
Old Apr 1, 2015 | 11:17 AM
avendo's Avatar
no answer on this i guess...
Old Apr 1, 2015 | 11:23 AM
JC Colon's Avatar
You can Jerry Rig them so they come on when the car is turned on. But that's a good deal of under the dash work. If you have the Haynes or Chilton manual for the car you can see how it's wired. Then figure how to wire it the way you want! But in order to do it right you Need the wiring diagram!!!!
Old Apr 1, 2015 | 01:52 PM
ohara's Avatar
You may also be able to run a "hot" wire from the daytime running lights to the fog lights, but not certain if this would effect the lighting system in anyway, but it's probably how I would do it, although they may turn off when the daytime lights turn off
Old May 1, 2015 | 12:08 PM
avendo's Avatar
power to key to fogs,they will be on till they burn out,replace repeat.
Dubstepticon
Oct 15, 2013 09:57 AM
Murray137
Oct 16, 2012 07:49 PM
brokensmile3800
Jun 22, 2010 12:53 AM
PCWeber
Oct 9, 2008 12:15 PM
montejass
Jun 16, 2006 12:25 PM
