fog light aiming
Old May 25, 2009 | 01:48 AM
Blown04SS's Avatar
Default fog light aiming
so my passenger side fog light is aimed pretty much straight down into the ground. anyone know how to aim the ****ers? they're hard enough to get to as it is. im thinking of swapping bulbs while im in there.
TIA
Old May 25, 2009 | 08:17 AM
The Popcorn King's Avatar
I'm sure someone will chime in on how its done. Since i have a 5th Gen, i couldn't just go outside and look for you. But i would if i could.
Seeing how this is a holiday weekend, people are either asleep or away. So give it time for an answer.
Old May 25, 2009 | 10:46 AM
bowtietech's Avatar
The best way I have found to gain access to the foglamps for bulb replacement or aiming is to remove the headlamp assembly. Once the headlamp is out of the way it is very easy. No horizontal adjustment can be made,only vertical. I have not had the need to adjust the foglamps on my 2007 SS but I believe there is an adjustment screw on the foglamp assembly that is easy to get to with the headlamp removed.
Old May 26, 2009 | 01:35 AM
Blown04SS's Avatar
thanks, i never would have thought to remove the headlight for better access. i only need to aim it up more, you know so it actually hits the road instead of the inside of my bumper lol..i noticed it the other night when driving with just the fogs on and i could only see the drivers side beam. so i actually stopped and checked to see if i had a bulb out but i didnt, just very bad aim. i assume from the bumpy *** roads i have to drive on around my house. hopefully its still fully attached to the car, and not half broken...that would be my luck though
guzzimane
Apr 27, 2014 10:02 AM
natedawg061987
Dec 5, 2012 03:44 PM
natedawg061987
Sep 28, 2012 08:56 PM
ranger9
Oct 12, 2009 12:02 AM
