Fixing seat belts
Old Apr 4, 2011 | 09:57 AM
saigashooter's Avatar
Default Fixing seat belts
So my drivers seatbelt is retracting slower and slower. does anyone know if the tensioner/retractor can be serviced and cleaned? Really tired of having to manually retract it.
Old Apr 4, 2011 | 10:05 AM
mine is the same way, you can pull the molding off to see the retractor and see if there is anything caught up in it, I'm going to look into mine next time i'm home and i will let you know what I find out
Old Apr 4, 2011 | 10:45 AM
Look at this Seat belt fix I found on a BMW forum. Could work for you. Let us know...
Seat Belt Tension, Slow to Retract, Sticking....A possible fix!! - Bimmerforums - The Ultimate BMW Forum
Old Apr 4, 2011 | 11:42 AM
mrl390's Avatar
Try getting to the base of the retractor and making sure the retractor is straight up and down. If you turn the retractor at any angle except the position its mounted in the car, it will lock up. Its a safety feature in case you flip or roll your car. Sometimes the retractor will work itself off to one side and give you problems. Loosen the bolt, make sure the retractor is straight up and down and the belt operates properly and then tighten the bolt. It may not be your problem but its a good place to start.
1970monte454
Apr 18, 2012 09:01 PM
78monteman
Feb 27, 2010 09:09 PM
1970monte454
Feb 13, 2010 09:39 AM
1970monte454
Feb 7, 2010 12:20 PM
montefreak85
Jul 10, 2006 04:13 PM
