first gen. rebuilt front suspension
Old Aug 22, 2012 | 08:02 PM
zapp59's Avatar
Default first gen. rebuilt front suspension
Hi guys! I have a question about my 71 monte carlo. I just rebuilt my front suspension and now when I lift the car up with a floor jack it makes a clicking sound. sounds like it is coming from the control arms. I have loosen the bolts and moved it up and down, but still makes clicking sound. Now its mainly when I use the floor jack in raising car up. the only thing I didn't replace is the the tie rods, but sounds are coming from around the springs and control arms. Any help will be appreciated.
Old Oct 29, 2013 | 06:32 PM
blaser's Avatar
rebuilt with factory style rubber peices or polyurethane? If poly, did the controlarm bushings get the included lube applied?
Old Oct 29, 2013 | 06:41 PM
When you mean rebuild...
What all exactly did you replace?
Old Dec 25, 2013 | 09:32 AM
19monte70's Avatar
Silly question, I have seen it before, are the shocks tightened down properly, the threads could be dragging across the upper mount when you lift it up.
Seth
elwood blues
Jan 24, 2010 12:35 PM
bumpin96monte
Feb 12, 2008 03:45 PM
