factory radio
Old Jun 12, 2006 | 10:18 PM
ruckus42's Avatar
Default factory radio
i have a 2001 monte ls. recently my factory radio has lost all sound. it turs on fine but has no sound. any advise would be appreciated.
Old Jun 14, 2006 | 01:46 AM
erik2282's Avatar
Default RE: factory radio
I'd check the connections at the amplifier, the radio and all other connectors in-between. check fuses. umm have you recently done anything to your car? or like take something apart? done something to your trunk? put something big in there that could've pinched a wire on the amp?
Old Sep 28, 2006 | 08:56 PM
ruckus42's Avatar
i found that it was the amp itself! if anyone else is having this problem, you can get one from a junk yard. you may have to switch the external housing because not all the mounts are the same. its not all that diff. at all.
Old Sep 28, 2006 | 11:07 PM
Bigg J's Avatar
SOLUTION!!
Good job, guys!
Old Sep 30, 2006 | 02:21 AM
SoCalSS's Avatar
Wow... that was short, sweet and to the point... I like it.
guysnydr
Sep 18, 2013 07:43 PM
billyjblunt79
Aug 13, 2012 10:23 AM
ralphtrent
FWD Tech Guides '95-'07
Nov 28, 2010 04:35 AM
Intimadator4
May 27, 2006 06:33 PM
zipsayain
Mar 17, 2006 12:55 AM
