evap. purge valve
Old Jul 21, 2014 | 05:35 PM
lilboxx's Avatar
Default evap. purge valve
hello all i have a 2000 monte ss with the 3.8 the issue im having is the previous owner of the car needless to say wasnt very mechanically inclined and did more harm then good the 2 hoses that come off of the throttle body to the evap purge valve on the top of the motor are not the original ones for the black hose that connects the 2 to the throttle body is broken and the hoses are zip tied in one of them always falls out and ends up dripping gas so the car rarely gets driven im really just wondering if anyone has a clue of where to get the new hoses for this part from the throttle body to the purge valve?
thanks
Old Jul 21, 2014 | 07:03 PM
owens91's Avatar
either the junkyard or the dealer ship, the dealership will charge around 40 bucks and if you talking about what im thinking its dripping gas because of the fuel pressure regulator
Old Jul 21, 2014 | 08:32 PM
lilboxx's Avatar
Okay thank you and i do believe youre right! Any idea if that would cause the car to sometimes stall right after its started?
Old Jul 21, 2014 | 08:39 PM
owens91's Avatar
That would deff be the fuel pressure regulator. Had the same problem. Either its failing or failed. But once you replace it u should be fine
Old Jul 21, 2014 | 08:41 PM
lilboxx's Avatar
awesome thank you very much !!
Dam20735
Jun 27, 2013 04:17 AM
aurgathor
May 24, 2013 06:30 PM
hectorloko88
Mar 23, 2013 09:11 AM
mrl390
Aug 27, 2008 05:31 PM
