2nd Gen ('73-'77): Engine swap
Old Jan 26, 2019 | 04:09 PM
Rat Fink's Avatar
Default Engine swap
Hello, I am new to all this so please bear with me. I have a 73 Monte carlo that I bought that has a 350 in it and it has a big block vin# so I bought a 454 motor for it but then had an after thought that might be costing me, will this 1991 gen5 454 big block accually bolt up under the hood. I was going to just pull the 350 and give it a go, but being a disabled 55 year old man makes this way a very time consuming way, so I thought I would ask some of you that might know these cars a bit better than I. does anyone have any ideas on this that might help me?
Old Jan 26, 2019 | 05:23 PM
Jeffs02rwdSS's Avatar
Yes a fuel injected 454 will bolt up directly under the hood. A few thing would be needed as a electric fuel pump and depending on what induction (carb,fuel) you would need a different intake manifold to run a carb. Other than that I don't recall anything else that would be a big issue. Good luck
Old Jan 26, 2019 | 06:23 PM
Rat Fink's Avatar
Default Engine swap
Thank you very much for the information, it is sure going to help me out. glad to be a new member of this forum. It's nice to have the help of some knowledgable people thanks again.
Old Jan 26, 2019 | 07:07 PM
Glad to be assistance, tons of members here to share knowledge and opinions. Welcome to the forums
pittbuckeye84
May 23, 2018 03:53 AM
86Monte305
Nov 10, 2013 06:13 PM
elnino
May 19, 2010 01:26 AM
ChevyRider10
Nov 3, 2009 05:51 PM
76MonteMan
Sep 15, 2009 11:08 AM
