81 swap
Old Nov 3, 2009 | 02:07 PM
ChevyRider10's Avatar
Default 81 swap
I'm thinking about getting a 1981 Monte Carlo. Now the thing is it only has the 229 4.4 L in it. Apparently this rates out to 110 horsepower. I wondering if this car if fast compared to the 1999 3.1 L. Also, I was wondering about common engine swaps for the 4.4 L. I was thinking of a 350 swap, but looking at Google for this seems to bring up mostly 400 swaps. I want something that will be easy to drop in with very minor adjustment and a lot of power. Any suggestions?
Old Nov 3, 2009 | 03:45 PM
Budsjlm's Avatar
350 swap should be really easy get a carb hei vacume advance dist base depending on the trany you go with you'll probably need a new x member i'm looking at Gforce xmember for mine
Old Nov 3, 2009 | 05:51 PM
drewskie043's Avatar
the 350 swap will be almost identical to the 400 as they are both small block chevys and externally the same physical size, just different bore and stroke. they will have virtually the same parts also, so if all you're finding is 400 builds, it would still be a good guideline you can follow.
Budsjlm
Apr 3, 2012 05:43 PM
batman
Feb 16, 2006 03:18 AM
rchurch
Apr 29, 2005 05:49 PM
mickey
Apr 27, 2005 03:36 PM
earthquake
Nov 27, 2004 06:29 PM
