engine shuts down
Old Oct 19, 2009 | 01:24 AM
ssblackbeauty's Avatar
Default engine shuts down
I have an 01 ss. i was just driving along and engine just shuts down. it will crank but wont start. i replaced the fuel pump about 2 months a go. any ideas?
Old Oct 19, 2009 | 03:00 AM
jimbo7's Avatar
overheating?
need more details
Old Oct 19, 2009 | 08:06 AM
locknload's Avatar
When it was running was it having problems accelerating? If it was check your cat, i had my cat plug on me and it did the same thing, i was on my way home from work and the car kinda just shut off. It would crank but not start, i had to give it a fair amount of gas to get it over and running.
Old Oct 19, 2009 | 04:05 PM
it wasnt overheating at all. i was doing like 60 mph and there wasnt any sign except when i tried to go faster the engine was off. no check engine light at all. kinda weird. im thinking its probably crank position sensor, or cam sensor, or ignition module. im not getting spark. im getting fuel and air so im leaning towards ignition module.
Old Oct 20, 2009 | 07:58 AM
MAMONTE's Avatar
Yea it could be an ignition coil, which is an easy fix.
The problem is, without a code, its hard to really tell for sure with problems like this.
I've had a crank position sensor, and ignition coil go out on a 3.8L...
Old Jun 15, 2010 | 08:58 AM
Did you say you ARE getting fuel? If you're not sure if you are, I would check the relay/fuse for your fuel pump. I know when I changed my fuel filter, I pulled the fuse out while it was running (to get the pressure out) and it kiilled the engine pretty quick.
JigJig
Dec 15, 2020 02:28 PM
montecowlo
Dec 1, 2014 10:23 AM
b1chmonkey
Feb 16, 2014 10:25 PM
kody02ss
Dec 28, 2011 12:01 AM
mavrickf1613
Jun 30, 2009 12:59 AM
