Engine problems 2003 SS
Old May 19, 2012 | 03:34 PM
Kutter's Avatar
Default Engine problems 2003 SS
Oil leaked into the coolant system, I heard from a couple meachincs it's a cracked intake manifold.
Is this a issue with the 3800 engine, has anyone else had this problem?
Thanks
Old May 20, 2012 | 12:08 AM
Justin Knight's Avatar
It can be a common problem if you trust the tech get them to fix it unless you can get it done properly by someone else at a good cost.
If the engine had dexcool antifreeze the engine will be fine after the oil is flushed not just changed. If someone changed it to green coolant the engine is likely not gonna last more than 15-20k before problems will start to show.
Kenny Guido Temprano
Oct 8, 2015 03:48 PM
MonteCarlo 2003
Apr 21, 2015 06:09 AM
FM91
Jul 20, 2012 09:05 AM
lolligirl56
Oct 19, 2009 10:16 PM
rockford87
Oct 28, 2008 09:13 PM
