Engine data interpretation
Old Sep 6, 2010 | 08:41 AM
emt1134's Avatar
Default Engine data interpretation
I would like to compare some parameters with other members. I have a 2003 Monte Carlo with a 3.8L w/out supercharger. My desired idle seems a bit out of range, and my long term fuel trim seems a bit high. I did a lower intake manifold gasket replacement, but did not change out the upper plenum gasket.. However, I do not know what my readings were before I performed the work.. Also, all engine components are stock.. Thank you in advance..
Note: these parameters were taken at idle, in closed loop, with engine running at normal operating temperature.
Actual RPM: around 740
Desired RPM: 696
Short term fuel trim: fluctuates between -1 and +2
Long term fuel trim: +8
HO2S1: normal fluctuation
HO2S2: steady
IAC count: 28
Old Sep 6, 2010 | 10:49 AM
nitehawkjcb's Avatar
Everything seems fairly normal, but your LTFT indicates that you may need a tune up - or maybe a vacuum leak or exhaust leak.
Old Sep 11, 2010 | 09:24 AM
Justin Knight's Avatar
the slightly high idle and long term fuel trim values would make me think its a very slight vacuum leak somewhere. check all you vacuum hoses and throttle body gasket after the MAF and i'm sure you'll find something. if not the UIM gasket is probably leaking.
minttbird
Nov 25, 2013 09:57 AM
RickCoMatic
Dec 13, 2008 05:26 AM
J_Bru_Ha_SS
Aug 16, 2006 04:03 PM
bobsicparts
Oct 24, 2005 07:07 AM
bobsicparts
Oct 23, 2005 03:21 PM
