6th Gen ('00-'05): engine block coolant capacity
Old Aug 16, 2019 | 08:05 PM
sandaygo619's Avatar
Question engine block coolant capacity
I got a 01 monte ss and i Need to flush my coolant since the previous owner of did not use dex-cool and I wanted to flush the block with water but I need to know how much the block can hold so i get the coolant to water ratio right. I know the 2 knock sensors are drain plugs for the block that i can use to empty it so I am able to fill it up completely with premixed coolant but id rather not touch those at all.
Old Aug 18, 2019 | 07:48 AM
Jeffs02rwdSS's Avatar
If you go as far as draining the block by pulling the knock sensor and draining the radiator you surely can just add premixed coolant and just top off. I might suggest flushing the coolant first and back flush the heater core ( remove hoses from engine and run water thru both directions) if it's been a long time. Good luck
1st-monte-ls
Nov 21, 2019 12:37 AM
ajay654
Jan 7, 2018 09:35 PM
Kmac96
Aug 17, 2017 06:56 PM
smitty911
Oct 6, 2010 12:22 PM
70monte1
Aug 31, 2010 08:43 PM
