Electrical Issue/Cruise light and DIC
I searched the forums here but didn't find info on the exact problems I'm having. I am having some issues with my 2003 Monte Carlo SS. 84,xxx miles stock except K&N cold air intake. Over the weekend, cruise control turned itself off and wouldn't turn back on, but then the cruise light on the dash came on but cruise control wasn't working. I tried turning cruise back on and it took so many tries to get it to engage, it worked for a few minutes and turned itself off again. I pulled the fuse out for cruise control since I read on the forums here that someone had a scary experience with cruise turning on by itself.
The past two days when I turn the car on, the cruise light stays lit on the dash for anywhere from 15 seconds to a minute. The driver info center doesn't turn on for about the same amount of time. I don't know if this could be related but about a month ago, I was driving with my high beams on and the headlights went out and I had to click to the low beams to turn them back on. That was the only time that happened. I plugged my ODB scanner in but it didn't come up with any info. I am pretty strapped for cash and the closest dealer is a good 30+ miles away. From what I've read it could be the bcm, pcm, or ignition switch. What do you all think?
I'm bringing her to the shop on Friday so they can scan it with the Tech 2 tool. Now the ac/heat fans aren't working. When I turn them on, the cruise light on the dash turns on and stays either solid or blinks. (I took out the cruise control fuse so I'm sure it's not a cruise control issue) The driver info center turns on sometimes and other times it doesn't even turn on at all. Hopefully this can fixed easily and inexpensively. I'll post here when we figure out the issue to help anyone else out in the future.
Update: The issue got worse. The cruise light would stay illuminated unless the fan was turned on. The fan would work intermittently and the Driver Info Center would take a long time to turn on.
A new ignition switch fixed this issue.
This thread has been inactive since 2012. You will be better off starting a new thread about your issue.
7th Gen ('06-'07): DIC messages: Service brake system, brake assist and traction control
monte carlo 3831
May 22, 2014 07:36 AM
rchadhaney
Apr 1, 2012 02:36 AM
