6th Gen ('00-'05): EGR system help
Old Mar 24, 2026 | 09:40 PM
joekeet32@gmail.com's Avatar
Default EGR system help
Repair help
I have a 2002 that has immense power loss and is running weird. It runs a little better off a cold start but has trouble starting when warm, it starts then almost stalls out then idles fine whenever you give it a little gas. The exhaust used to be much louder and deeper (it’s cut off past the cat) and now it just just like a Libranian shhhhhhing you. Attached below is the live data and the codes it’s currently throwing.
Codes
P0403 (stored)
P0404 (stored)
P0405 (stored)
P0404 (pending)
2% calc load at idle
Ect 217 Fahrenheit
Stft b1 10%-20%
Lftf 21.9%
MAP 12 inHG
Engine rpm 685-750 rpm at idle
Spark adv 19
IAT 133 Fahrenheit
MAF .4 lb/min at idle
TPS .4 %
O2S B1 S1 .09-.7%
STFT B1 S1 19.5-20%
O2S B1 S2 .15-.5 but stays on the lower end
Stft B1 S2 99.2% (has been that every reading I’ve taken might be broken)
AsTheDaysOfNoahWere
Dec 23, 2024 09:24 AM
avendo
Jun 26, 2023 09:15 AM
obeymyego
Mar 24, 2015 10:15 PM
YelloJac
Feb 24, 2013 11:48 AM
itsjustme
Oct 20, 2010 02:37 PM
