Drivers side power window switch
Old Oct 11, 2010 | 09:57 AM
paudemge's Avatar
Default Drivers side power window switch
I'm having an issue where the drivers side power window switch will quit working, when it quits working I won't be able to raise or lower either the drivers side or passenger windows, however the passenger side switch will still work to lower or raise the passenger side window.
I usually notice it has quit working when I first get it in it, but it has stopped working once while I had already been driving for a few minutes.
I removed the door panel to see if I could see any visual problems and I knew I would need to remove the panel any way to replace the switch. I can't see any visible problems and can't relate any activities to why it stops working or why it just as suddenly starts to work again. It may work for a week or more and then just quit again.
After looking around these pages I see that if I do replace the switch, I should only replace it with the OEM version,since they are fairly pricey my question is:
How likely is this a bad drivers side switch?
Also I guess the passenger side switch won't work if the drivers side switch is not installed?
Old Oct 11, 2010 | 10:07 AM
darcor's Avatar
check wiring where it goes from the door to the intereior. lots of times the wires will break from opening and closing the door.
Old Oct 11, 2010 | 03:44 PM
paudemge's Avatar
OK I'll give that a look.
BTW it is a 2006 lt
Old Oct 15, 2010 | 07:05 PM
paudemge's Avatar
Couldn't really see much because of the protection over the wires and didn't really want to mess with it because I wasn't sure how to remove the rubber protective cover without damaging it.
But it has been pretty good now for over a week, I guess I'll just put the door panel back on and hope it stays good for now.
suburbiangiant
Dec 16, 2024 10:03 AM
nemii
Dec 10, 2017 08:30 AM
Furder2010
Dec 10, 2012 10:29 PM
tekboi
Dec 6, 2010 06:25 PM
sarti8054
Feb 15, 2010 07:03 PM
