Drivers door speaker Not working
Old May 9, 2014 | 11:12 AM
little red ss's Avatar
Default Drivers door speaker Not working
Hello I have an issuse with the drivers door speaker not working on and off. I noticed when the chimes work the speaker works I have checked every thing I can think of Has any one else had this issuse and how did you fix it.
Old May 9, 2014 | 02:20 PM
Your speaker might be blown or maybe a loose connection somewhere along the wire.
Old May 9, 2014 | 06:19 PM
JC Colon's Avatar
You said when the chime works the speaker works? You chime runs through your radio. So you may have a bad factory head unit!
Old May 9, 2014 | 07:56 PM
Barovelli's Avatar
I wonder if the factory amp in the trunk feeds the front speakers. If so it may be bad.
I only jumped in on the thread b/c my passenger front is super,super low volume and it has a slight buzz to it. Thought about finding a loaner amp to swap in and see if that was the cause.
kmapesii
Jul 27, 2013 06:01 PM
tps221
Mar 10, 2012 09:54 AM
Crusader SS
Mar 26, 2011 11:39 PM
koebbe
Oct 13, 2008 07:50 PM
Stag
Nov 23, 2006 10:45 PM
