door pin fix?
Old Feb 27, 2011 | 10:08 PM
original87SS's Avatar
Default door pin fix?
the door pin on my 1987 monte has become so loose( you can move it around quite a bit with your hand) that the door wont completely shut...
how can i fix this?
Old Feb 27, 2011 | 10:11 PM
not sure if you have ever heard of this place but it might be a good start!
http://dixiemontecarlo.com/items/DM30042.htm
Old Feb 27, 2011 | 10:32 PM
No, I haven't heard of this place. Thanks for it.
I'm not talking about the hinge. I'm talking about the part the door mechanism releases when you open the door.
Old Feb 27, 2011 | 10:34 PM
mrl390's Avatar
Do you mean the door striker? There should be bolts that hold the striker tight. They may have just came loose.
Old Feb 27, 2011 | 10:40 PM
try here also, and bookmark it for future use!
http://www.mikesmontes.com/index.asp
Old Feb 27, 2011 | 10:44 PM
Ya it's the stricker. How do I get to it? Behind the interior panels?
Monte Carlo 3831- do you have any more good websites? Haha.
I'm in the middle of restoring my Monte, so these websites might be useful.
Old Feb 27, 2011 | 10:57 PM
Budsjlm's Avatar
it it's self is the bolt, the inside is the nut, you should be able to find the torx bit to fit it and tighten it up, just make sute you get it ligned up
pic for refrence on torx bit
Old Feb 27, 2011 | 11:41 PM
Ok thank
Old Feb 28, 2011 | 06:48 PM
well what if the striker is broke... so tightening isnt working
Old Feb 28, 2011 | 07:07 PM
Budsjlm's Avatar
you'll have to replace it
Http://www.dixiemontecarlodepot.com/...earch.aspx?p=1
you'll probably have to get the plate also which is on the inside of the body, it can be accessed by removing the interior panel
Dixie doesn't have any, you should be able to get one from any G-body could probably get them from a junk yard
sounds like it's stripped
saigashooter
Mar 5, 2024 03:12 PM
MJClemm
Oct 30, 2012 11:08 PM
1ATony
FWD Tech Guides '95-'07
Feb 1, 2011 01:23 PM
Montecarloconvertible
RWD Tech Guides '70-'88
Jul 2, 2010 11:14 AM
Arisa
Mar 1, 2006 12:05 PM
