Dimmer Switch and Lighting Problem
Old Jan 17, 2011 | 09:43 AM
chamberz's Avatar
Default Dimmer Switch and Lighting Problem
Here i go again first problem i have an 2001 monte carlo Ls
1. Dimmer switch isnt working correctly. It controls the inside lights correctly but for the headlights if i cut them on they stay on no matter what time of the day it is. ( it acts as if its in the completely pulled out setting) but in the middle position is supposed to be parking only but that doesnt work.
2. once the headlights are on they stay on until the car has been off for for a long time i say around 5-10 mins idk but way to long and then someone goes off in the passanger fuse box which makes a click click noise and then they will go off.
PLEASE HELP
Old Jan 17, 2011 | 10:13 AM
chamberz's Avatar
To add i already tried replacing the dimmer switch so maybe the wiring to the dimmer switch or something
silverodo12345
Nov 20, 2013 05:28 PM
Harlan2012
Feb 6, 2013 01:39 PM
matrx10503
Aug 25, 2010 03:12 PM
Brandona0524
Feb 22, 2010 11:20 PM
