6th Gen ('00-'05): Degraded power
also is it worth replacing the MAP sensor just to replace it if Im not getting a code or anything? just curious, as I have cleaned the Maf sensor,replaced the cat,going to replace the pcv? any benefit by replacing the Map?
Check out this website: MACGP
Nah, not worth it if nothing is wrong with it.
hi, I sent you a message, not sure if im getting it right tho? Im getting a sporatic hum with a abs/traction control light,sometimes just the hum while driving at lower speeds,replaced both front wheel hub bearings,is this the abs brake module pump kicking on? a bad fuse? or?? I respect your input brother!! thanks!! Claydoh
If you are getting ABS lights, you should be able to get the code read and see what is throwing the fault. Definitely start with checking the wiring though
update: put my new Monroe quick struts on, all 4,front was a breeze the back however was kinda a pain in the ***! got new tires and alignment today,Falken Ziex ZE 912 tires. not quite as sporty as I wanted but I got a great deal. I also had got a $120 rebate visa card on the struts and a $ 50 card for the new cat, which I paid on the tires. Man oh Man what a difference!! all this fixed my shaking I had at 60MPH,tightened up my steering and of course new shoes are new shoes!!! I think I am going to replace my front sway bar end links next with poly bushings! any comments? ZZP or Moog? as always thank you for your assistance!!
I am using moog sway bar links and love them. You could also upgrade to a gmpp front and rear sway bar with poly bushings for it if you wanted better handling.
billyjblunt79
Jan 3, 2014 11:40 AM
tbmaniacal
Nov 29, 2010 02:09 AM
